Bro, its the been there done that scenario you are implying, you want innovation?? Hows compounding the area around nuts in the engine bay to remove the darkened areas? What about polishing the dashboard with petroleum jelly? Hows polishing the accelerator cable and wire covers with turtle wax black chrome to bring out the rich darkness?? How about taking tires of an then usin petrol to remove the tar on the suspension and undercarrige? Ever tried polishing the aircon pipe joints an the aluminium air con pipes that carry the gas with brasso? Bet this never happened in your detailing career, put the car
s front up on hydraulic jacks, lie upside on a skateboard and get under the car with a diesel an surf mixture to clean the engines firewall? Jacked the car from the left an gotten under the car to clean the oem exhaust with 1000 grade sandpaper an water ? :)
Large companies spend billions well millions on research for products development, yes some products are down right nasty but some do work........we can achieve average or a lil above average results with our own sapashal farmulay, the guy i used to get my car washed from said he
ll make a marvellous solution, he put a lil shapmoo, some surf, along with diesel into a can an then then shook it a bit, added water an then put it all into a lota, an sprayed it onto the car, nearly 10 secs later it started to foam up an he said this will suck the dirt up, i waited an watched as he rubbed like a maniac.....when he was done with this stunt , i had a look underneath, an to my horror the fuel tank looked like it had a powdering accident, the rubber portions had mud stains on then, i had put in memory 3 points where i had seen tar an after the wash they were still there........I just shook my head, gave him pre soak, had his lota filled with water put just a teensy amount, then got that sprayed, waited for a couple of minutes, had him rub just lightly but thoroughly the whole undercarrige. He was like enday naal ki hona aay, aay tay buss companian fraud hi mardiyan nay, wekho aine chag nai bani......well after he done an he washed the undercarrige...........he was at loss of words, an i got another believer in pre soak. You can get results from self formulated things, but when you want excellence leave it to the people who spent time an money getting there!
