Car feels heavy when AC is turned on and the RPM falls instead of increasing. Problem is both on Petrol and CNG.Car is CIvic 98 Auto.
What can be the cause I thought that RPM should increase when A/C is turned on.
May be its the a/c vacuum, also get the wiring checked.
this problem almost made me cry in my auto 98 civic getting throtle+tappets+kit service made my civic much better
facing same issue in my 02 city
Could be any of a lot many problems. Get it checked out from a learned mechanic.
you have to get it done through a good AC mechanic. Most probably the relays are not working properly. but again.. could be anything..
any update?
car 98 civic here (H). AC guy says to change compressor but i guess problem is somewhere else. Cooling is perfect,mileage is great and no issues at all. Perfectly maintained and all tuning done on time.
Termostate valve bad timings, regarding idle, bad iacv, need carby cleaner, vaccume leak, bad throttle cable position.
Sent from my HTC Wildfire using Tapatalk 2
all things are in good nick but no idea about thermostat valve. Gurmi bohat hai werna ajata
Koi nhe sardio ma karva lai ac set the guy i recommend u, us k pas ankhay band kr k chala jaaa one of my oldest trustee person
There is thing i dont quite recall its name but its purpose is to raise the engine speed when ac is turned on. two pipes go in it. If you dont want to change it then simply pull the choke to increase the engine speed then turn on the ac
yani pehle choke lagwayen aur phir usko khenchen bheeee
