i had an XE, well i still do but i changed the engine recently after tweaking everything of its original engine for 5 years. anyways,
what you need to do to get rid of vibrations is to get ignition system serviced.
check condition of stubs on inner side of distributor cap, they shouldnt be worn out or corroded. best is to replace the cap with a kaabli one that has good stubs.
make sure you are using the right spark plugs. replace if current ones have logged >15k kms.
clean out the air filter. make sure there are no vacuum leaks on the carb tself, usally some of the rubber pipes on carb develop minute cracks/leaks over time.
let us know of any changes and results...
