Billionton Car MP3 Player For Sale
Rs.2000 with 64 MB Flash Drive
[ATTACH=CONFIG]473657[/ATTACH]
The CARMP3 uses the OTi-6888 is a USB host with MP3 interface controller. User can stores the mp3 file in the USB flash disk. When the USB flash disk plug in USB port and push the play key. The OTi6888 will read the mp3 file from USB flash disk, and send the data to the OTi-001316V01, that is a single-chip solution for an MPEG layer 3 audio decoder, that can transmit audio signal to the BH1417F is a FM stereo transmitter IC that consists of a stereo modulator for generating stereo composite signals and a FM transmitter for broadcasting a FM signal on the air.
Features:
? The host controller conforms to Full-speed (12Mb/s) USB Specification, Version 1.1,and 14.318 MHz external clock
? Supports the USB flash disk device(Version 1.1 or 2.0) with Mass storage class
? Search for whole disk (MP3 File)
? Input button for Play (Pause), Previous, Next, Volume + and Volume –
? MPEG audio layer 1, 2 and 3 decoder supports MPEG 1 & 2 for all layers, and Layer 3’s 2.5 extensions, and all their sample rates and bitrates, in mono or stereo Operates with single clock 24.567 MHz
? Supports VBR (variable bitrate) for MP3
Specifications:
General Specification:
? Antenna: Built-in
? Resume-like function: start from the same song which played before power-off
? Power: DC12V using Cigarette Jack
? Displays: Power LED, Buttons LED, Remove USB Flash Drive LED
? Audio Out: FM Out
? Select Switch: Select a Channel (2 Dip Switches)
? Play Button: Play ( or Pause) MP3 music
? Next Button: Play next song
? Line Out: Transmits MP3 music to Car Stereo Speakers
? Supports 8 transmitter frequencies are lower frequencies 88.1,88.3, 88.5, 88.7MHz and higher frequencies107.1,107.3,107.5,107.7MHz.
Mechanical :
Length: 124.7mm
Width : 40 mm
Height: 22.6 mm
Certification :
FCC. VCCI
Environmental Operating Ranges :
Operating: Temperature : 0° to 55° C
Power Consumption :
Idle Mode : 45.1 mA
Read Mode: depend on different USB flash disk
Standby Mode: depend on different USB flash disk
LED Indication :
Blue and Orange Light on : Power On
Orange Light Flashing: Playing CARMP3
