[LEFT]BLUETOOT ,Ipod,dvd, With 2.7Inch LeD Brand New condition Complete Accessories
AND 718 SPeakers for sale....
ATTENTION !!!!!!!! BOTH DEMAND 18k Only !! Direct Contact me on MY Cell... UrGENTn Sale 0345 3113686no foolish offersChecks its specs first !!!then contact me !! if u Really Intersted Then Drop ur number With Good Offer i will contact u soon !! . note please dont give foolish offers,DROP UR NUMBERS IF U INTERSTED...Detachable Control PanelAt the heart of the KD-AVX11 is its motorized, detachable control panel. It's where you'll find the built-in 2.7-Inch LCD. With 560 x 220 resolution and a 16:9 aspect ratio, it's a great way to enjoy video and images, and you can select from several different wallpapers to get the look you like.CD and DVD Playback
Enjoy your favorite CDs or watch some video on DVD, DVD-R/RW, DVD R/RW or VCDs. Use the gold-plated video output terminals to send video to a passenger screen.AM/FM Radio
The KD-AVX11 features an AM/FM radio with standards like automatic presetting. You can also add SAT radio with additional accessories.GIGA MP3 MULTI--Play MP3, WMA, and WAV Files Burned on DVD
The KD-AVX11 features GIGA MP3 MULTI, which plays MP3, WMA, or WAV files burned on DVD. With MP3 and WMA files, the 4.7GB capacity of a DVD can store up to 2,500 songs on a single disc--equal to 250 pre-recorded CDs. If you want even more superior sound quality, WAV files can be burned onto a DVD. WAV is an uncompressed PC music file format that delivers CD-quality sound. A single DVD disc can store 100 WAV files--equal to 10 pre-recorded CDs. Now you can enjoy non-stop entertainment with CD-quality sound, without an additional CD changer.Bluetooth Ready
Bluetooth Wireless Technology is available with an optional adapter (KS-BTA200) for the KD-AVX11. A maximum of five compatible mobile phones can be registered for hands-free calling. With voice-recognition mobile phones, you can dial by just saying the name in your phone book. The wireless functions work even if your mobile phone is tucked away in your bag or pocket. You can also stream music from a compatible digital audio player, for listening on your car stereo.DivX Video Files
The KD-AVX11 system is a DivX Ultra Certified product, and can play PC-created DivX� video files on a DivX� can fit up to 10 movies onto 1 DVD, or 1 movie onto 1 CD, without sacrificing picture quality.Ready for iPod
You can listen to iPod music with an optional KS-PD100 adapter. The iPod can be controlled from the head unit, and song information is displayed with the same categories and layers as an iPod.MPEG 1/MPEG 2 Playback
Play MPEG 1 and MPEG 2 video files burned on DVD or CD, TV programs recorded from a PC, or personal footage from digital camcorders, without the hassles of authoring or decoding.JPEG Pictures
JPEG digital still photos can be displayed on their own or as slideshows.Setup/Control With the Multi-Functional Monitor
You can use the built-in monitor to set the system's parameters (EQ, balance, fader, etc.). Operation is easy with user-friendly interface and controls. Searching through music folders with GIGA MP3 MULTI is also a snap.Expandability
With its 50W x 4 MOSFET amplifier, the KD-AVX11 packs a lot of punch. But if you need more, three sets of preamp outputs (front, rear, and sub) are included.A/V Input
Connect external devices like video game systems with the A/V input.What's in the Box
JVC KD-AVX11 DVD/CD Receiver, trim ring, sleeve, remote control, wiring harness, installation hardware, installation manual, instructions[/LEFT]
- AMPLIFIER
- Power Output: 20 W RMS x 4 Channels at 4 ohms and less than or equal to 1% THD N
- Signal-to-Noise Ratio: 70 dB (reference: 1 W into 4 ohms)
- Load Impedance: 4 ohms (4 ohms to 8 ohms allowance)
- Equalizer Control Range: Frequencies: 60 Hz, 150 Hz, 400 Hz, 1 kHz, 2.5 kHz, 6.3 kHz, 15 kHz; Level: /-10 dB
- Line-Out Level/Impedance: 2.5 V/20 kOhms load (full scale)
- Output Impedance: 1 kOhms
- Color System: NTSC
- Video Output (composite): 1 Vp-p/75 ohms
- Input: LINE IN, VIDEO IN, Antenna input
- Output: VIDEO OUT, DIGITAL OUT (optical)
- Others: CD changer, OE REMOTE
- FM/AM TUNER
- Frequency Range: FM (with channel interval set to 100 kHz or 200 kHz): 87.5 MHz to 107.9 MHz
- FM (with channel interval set to 50 kHz): 87.5 MHz to 108.0 MHz
- AM (with channel interval set to 10 kHz): 530 kHz to 1 710 kHz
- AM (with channel interval set to 9 kHz): 531 kHz to 1 602 kHz
- FM Tuner Usable Sensitivity: 11.3 dBf (1.0 uV/75 ohms)
- 50 dB Quieting Sensitivity: 16.3 dBf (1.8 uV/75 ohms)
- Alternate Channel Selectivity (400 kHz): 65 dB
- Frequency Response: 40 Hz to 15 000 Hz
- Stereo Separation: 35 dB
- AM Tuner Sensitivity/Selectivity: 20 uV/35 dB
- Signal Detection System: Non-contact optical pickup (semiconductor laser)
- Frequency Response: DVD, fs=48 kHz: 16 Hz to 22,000 Hz; DVD, fs=96 kHz: 16 Hz to 22,000 Hz; VCD/CD: 16 Hz to 20,000 Hz
- Dynamic Range: 93 dB
- Signal-to-Noise Ratio: 95 dB
- Wow and Flutter: Less than measurable limit
- MONITOR
- Screen Size: 2.7 inch wide liquid crystal display
- Number of Pixel: 123 200 pixels: 560 (horizontal) x 220 (vertical)
- Drive Method: TFT (Thin Film Transistor) active matrix format
- Color System: PAL/NTSC
- Aspect Ratio: 16:9 (wide)
- Allowable Storage Temperature: -10 degrees C to 60 degrees C (14 degrees F to 140 degrees F)
- Allowable Operating Temperature: 0 degrees C to 40 degrees C (32 degrees F to 104 degrees F)
- GENERAL
- Power Requirement: Operating Voltage: DC 14.4 V (11 V to 16 V allowance)
- Grounding System: Negative ground
- Dimensions (W x H x D): Installation Size (approx.): 182 mm x 52 mm x 160 mm (7-3/16 x 2-1/16 x 6-5/16 inches)
- Panel Size (approx.): 188 mm x 58 mm x 14 mm (7-7/16 x 2-5/16 x 5/8 inches)
- Mass (approx.): 2.1 kg (4.7 lbs) (excluding accessories)
