[I]1 Control arm rear bush2 Control arm3 Anti-roll bar link4 Driveshaft damper weight5 Engine oil filter6 Oil cooler hose7 Air induction trunking8 Radiator9 Exhaust downpipes10 Sump drain plug11 Radiator fan12 Gearbox sump13 Driveshaft bellows14 Brake hose15 Steering balljoint attachment16 Engine/transmission rear mounting17 Gearchange tube18 Exhaust pipe19 Brake pipe 20 Brake and fuel pipes
[/I]
1 Centre silencer2 Handbrake adjuster3 Handbrake cables4 Fuel tank5 Brake pipe6 Brake and fuel pipes7 Brake hoses8 Axle beam9 Axle mountings10 Spring11 Shock absorber mounting12 Fuel filler pipe13 Fuel gauge sender/fuel tank outlet14 Fuel tank breather15 Fuel filter*16 Fuel pressure regulator*17 Fuel pump*18 Towing eye19 Rear silencer 20 Rear brake pipes
tyre magec tell me some think about
Hi all. I started this topic way way back in good old days when i drove a turbo diesel charade. Forgotten my old password. Will try to recover it some day. I have come back to know the proper name of something called "Damer".Its that black stuff used by denters after repairing undercarriage. Can it be used to coat the undercarriage of a new car to protect against corrosion.Thx
I think you meant Gadri.Gadri ...... Sub-frame.It supports engine / suspension in some cars eg Cuore
Leaf spring is kamani or patta. Our 74 corolla used to break one after every inter city trip
Mukka = ?Cut choori ka paich = ? Maybe "Cut thread screw?"
Fender -> Mud Guard ?. Hain, these are different things.
You are right, its confusing.But, yes. Fender is called mud-guard or motor-guard.
Mud flap is called a "chikkar mat"
That's is right. Godda is the CV Joint on the axle.
Makhi
Rivot in english In punjab locally known as Missile.
Self kuppi.
Vaccum solenoid switch
Which controls accelerater and brakes with vacuum created by engine.
If we tell them proper name, they look at us and start laughing. Effects of too much gutka
Dubbi (ڈبی) --- Fuse Box
Control arms are called "chimta".
also mud gard
Ghuggi ........starter motor solenoid Moral hail......engine oilGayer buxa.....gear boxFlywheel gear ring.....karaCarburetor float........ punjabi word for testicles Needle valve.......naital vaal CV joint....godaWater pump......water body Leaf spring......kamani Exhaust muffler.......dholkiRocker arm ...... chiriyaRocker shaft.......bansuriExhaust baffle.....biffleDisc rotors.......taway
It's language problem It has nothing to do with the skill of mechanic.
