Remove heater pipe from engine side. Use a tap water hose to blow out the acid.
Do same for heater core.
If your tap water is not good then fill with RO water. Drain out. And fill half quantity of conc. Coolant.
Top up with your ro or distilled water.
Thats it.
If you are going to replace tstat with new then use the french or israel origin thermostat that comes in a genuine suzuki box.
