Please enlighten us with this top secret imaginary department that uses mercedes sprinter vans as fleet vehiclesâŚ
đ¤Ł
And bravo!! Once again you are basing your entire argument of âfaulty engineering â based on user reviews of âinjunn chakk maargyaâ and listening to some online echo chambers rather than find out with documentary evidence from the brand name that the engineering was actually dogshit
I can give you examples, of your favorite brand too.
Toyota 1zz had actual BS designed into it on the first iteration, toyota literally pulled a GM on themselves and used undrilled oil ring land pistons (on an engine without oil squirters, yea thats literally stupid as hell and toyota admitted to it and fixed it in later versions)
Toyota 2az early version has 130mm head bolts but only 20mm threads engage the block (this is not stupid but retarded), it was admitted by toyota and fixed it later models, for customers with bad engines, they sold an updated short block.
These are two very simple ones, there are lots of others too.
No engineering is perfect, no car is perfect, but if you bump in with arguments of actual design faults, its better to have actual meaningful conversations rather than some nonsense based upon online claims of some brain dead moron who only knows âtwist key to start, no result.. car is shit!, its engineering is shit. Its design is garbage - while the global market is using that same engine/body combo very successfully.
