RF receiver can be attached, which determines the noise on certain frequency, compare it with thresh hold level and could make a pin high which activates a cutoff relays.
Cutoff relays are hardwired, best I found was a wireless cutoff relays provided they be reliable and transmits a signal to activate the relay. Wireless relays can be installed anywhere, it’s becomes assort of headeque to trace it and remove it.
I have yet not found a good android app which once opened then could show the position of your car in real time. Not much is expected from Bachelors projects, like if you able to demonstrate that you can program a micro controller, knows little bit about designing PCB boards, designing a power supply, understands GSM module and be able to integrate the entire thing with GPS then that’s its self is a big achievement provided you able to complete what you started.
Having done the basic part, small tricks, add ons can make the project look very promising and be appreciated.
