Xli 2010 model car vibrates when release clutch in 1st and reverse gear otherwise gear shifting acceleration is proper .please advise
That's called Clutch chatter.You need to replace the clutch.
Weak pressure plate. Might have to replace pressure plate, clutch plate and bearing.
Similar is the problem in my xli 2012. Engine vibrates when i release the clutch. But if i release the clutch by keeping the car in race then there is no vibration
