You should get the Idle Air Control Valve or IACV checked. Your throttle body is closed and does not allow air through when you are idling. The IACV is a small motor that senses the load on your car and open a small opening to let air pass through the throttle body so the car can idle smoothly without rpm drops on any load.
If the IACV starts failing you will start noticing the rpm dropping to around 400 for a few seconds and then returning to normal. In worst case scenario your IACV is completely busted and your car will shudder and turn off because the IACV is unable to keep an openin for air to pass through.
Local mechanics call it "idle valve". Do not go for kabli. Always go for genuine parts. They'll be more expensive but will last you a long time and not make your car a continuous nuisance.
