dear friends,
please help me in a problem which is driving me nuts. i have taken my 2001 santro plus to almost 3 different electricians for complete 3 days but still none of them able to find the fault.
the problem is an under. 3 days ago all of a sudden on converting from cng to petrol, my car engine died as soon as i lift the foot off accelator. it was fine when i switched back to cng. next day i went to an electrician, he saw a sensor wire adjacent to coils out of its place sonit attached it back and problem solved. but next morning car started jerking off and on on cng specially in 2nd and 3rd gear so i shifted to petrol and it ran fine for 5 kms till it also almost died when i was slowing down at a chowk, shifted gears and this time, in first gear it was stuttering, jerking and not taking speed on pressing accelerator, i shifted to 2nd gear but still pressing accelarator harc till end the car will just moving like a snail, till i converted it back to cng and it was fine.
this time first took it to the best cng mechanic in peshawar who did cng tuning, found a broken spark plug, changed it, checked spark plus cables on volt meter, found it fine, also checked advancer found it ok. after that when i went out on try this time again it was fine on cng but as i converted to petrol, it started sputtering, occasional misfire and not taking accelerator, again switched back to cng and it was fine. checked this again and again, it was happening every time on petrol so went back to cng mechanic, he told me he thinks fuel pump is the culprit, so go to an electrician.
went to electrician, he replaced the fuel pump with a new one, problem persisted, this time, not even starting on petrol. had to start from cng and convert to petrol and again engine died. he checked fuel lines, petrol was coming freely, then he opened injectors, checked them one by one, all were fine, their sensors were taking current so he saif injectors are also fine. changed air filter, still problem was occuring on petrol. it took me late till evening so finally brought back the car as it was too late.
now i am at loss. car is fine on cng. but wont start ( just keeps on cranking) on petrol. no check engine light comes on. sputters on petrol and completely shuts off on pressing accelerator if on petrol.
please some one help me. even electricians have failed to diagnose. what could cause this problem
