Of course carburator would need to be removed. But I don't think WD-40 would be enough. I have tried several lubriacants, drop of kerosene oil, WD-40, many thing to wet the outer threads of cavity inside which adj screw is tightened. But no avail.
I have saw some tips of such jammed screw on internet. recommended is after dismantling everything do a small drill in the middle of screw head. then forcefully penetrate a small flat screw driver or hex key such that it inserts into the drill hole very tight then try to twist it in both directions. This requires lot of precise work and definitely the adj screw would be dumped. would need another adj screw.
any other easy way out?
