If the converter's inner honeycomb mesh has been removed then its most likely that rest of the stuff inside the converter has been taken out also.
The sound of the exhaust is louder due to that as the empty converter shell is resonating. Either stick with this one or else if sound is an issue then you will need to replace it which depends upon how much you can afford.
Broken Catalytic Converters can't be repaired. Period.
