Need catlatic convertor for passo 2014
Anyone can give me idea about price and availability in Islamabad Thanks
I used to carefully remove the filter and replace the lower one with the Dhloki sort of thing to cover up the noise and other aspects.In my 2003 and 2006 model Vitz there were two in each.. one close to the engine and other in underneath in the housing.The first one chokes more since its close to engine so removed that first.. then on removing the lower one i had to install the dholki.Rest you need to explore.
6k from peshawar
Around 7-9,000 PKR is the price. And you can find it in Chah E Sultan. Before buying it, try to bargain up to the max. Possible extent.
Basit bhai @basitali87
