I hv a 84 model CD 70, hv totally restore from its engine. Hv done following alterations
1)replaced 72cm cylinder to 78cm cylinder and putted a bigger glass
2)put a new STAR head and done sum alteration in Walls
3)Suzuki SD110 Piston
4)then change its Quesion gherari to 20/65 size as it will make sum performance in long run
5)Weight Of Star wd sum alteration
6)then cnvrtd Point into CDI kara of 125, 125 plug coil and 125 CDI unit
7)125 Carb.
8)38/15 spocket to hv a gud shoot in the intro. gears
Rate this ride !
