ASSALAMOALIKUM, Hope you all doing well.
I've recently rebuilt my CG-125 model 1987 on CDI technology. Overall it was a good experience but I'm facing some acceleration problem. My problem is that when I start my bike it starts on first kick and bike also stand on idle speed without pulling the accelerator. But when I pull the accelerator bike turn off.
Let me explain you further, for example if we take bike accelerator on a graph of 1-10. Bike works perfect on 1(means no accelerator is pull and bike is on idle speed) and also works perfect between 2-10(means a certain RPM to High RPM). Problem is that when I pull the accelerator between 1-2, I repeat 1 to 2 then engine decrease RPM and bike turn off automatically. But if somehow I'll manage to accelerator directly to 1-3 RPM then bike work perfect.
I've already changed accelerator cable along with slide and pin of carburetor but effect were found also I've tried increasing race from the air mixture nut but still no solid results were found.
If anyone of you faced this problem in his CG-125 please do help me.
Jazak'Allah
