Please suggest a good mechanic near bahadurabad area in Karachi to change the engine and gear oil for Vitz 2008?
Which oil is best for engine and gears?
Should I change it at PSO pump near Aga Khan Hospital?
Your corporation would be appreciated. Thanks
Is it 1.0 or 1.3? Engine code would hep too.
Its 1.0. Engine Code 1KRFE. Transmission Axle code K410.
So which one you used for Engine Oil? Transmission is only Toyota's good.
trans oil , toyota cvt-lc 4 L
