I did it with Thermostat valve and proceeded as under:-
1. Poured in Liqui-Moly Radiator Cleaner.
2. Started the engine, turned on blower and Heater at max setting.
3. Idled for about 20-30 mins.
4. Turned off engine and allowed it to be cooled a little.
5. Drained all water from:-
............ Radiator by opening drain plug
............ Engine Block by opening inlet and outlet hoses
............ Expansion tank
6. Blowed into the radiator in an attempt to take out max water.
7. Closed plug and all hoses (Except expansion bottle)
8. Filled in Plain water for flushing
9. Repeated the procedure "Thrice" by idling 10-15 mins each time
10. Made all connections, fitted expansion tank and poured the Coolant.
........... After only one flush, foam from residual additive could be noticed but after repeated flushing, it all cleared out. You may do it any number of times till you've achieved your peace of mind. Whole process took about 2 hours.
