Salam all,I want to change rear tyre on my pridor to 90/90 or any other better. And the model is 2020, I heard that there is some difference in previous model and new model.Please suggest me and also pros and cons.
i would suggest yo to try Crown puncture free tyre and tube. available on Daraz also.
the rim size is same as cg125 but the main concern will be the width of the rim as the stock tire size is 2.75/18
my suggestion is to consider a different tread pattern rather than going for an oversize rear tire
because if you are facing road grip issues
a tread pattern with more contact area will eliminate this issue
so you think changing with 90/90 is not a good idea. me should change pattern
Go for pather trekker 90/90 with your recent rim ur all problems will be solved
