Need recommendations for swapping charade engine with vitz engine? And whether its is reliable for long term.What would be the cost of engine + gearbox?Any good mechanic recommendation would be a plus pointThankyou in advance
I will recommend to ho for Corolla Engine 2nz-fe
I second that 1nzfe or 2nzfe will be a better option.
Cost idea?
120k for 1nzfe manual. 2nzfe will be cheaper then that.
If you're in Islamabad you can visit us for engine swap discussion.. However what's your budget for the swap?
From karachi
What's your budget for the swap
@dani_kkEither you open another setup in Karachi too or start car towing services so that Karachites can send their cars by trailor to you for swap and other quality works.
I'm already giving such services.. We reduce the labour cost as a compensation in tow charges.Many people send there cars via tow.
