today the suspension work was done here are the detials
old shocks were a bit in bad condition so changed all four shocks with spring (kabile ones)
all four wheel bearing were changed . rest of the hub were in good conditon so only cleaned them a littel bit .also brake disc plates were a bit dirty so sand papered it .
the steering cross has been very worned off so it was also changed with a clean kabli one,
the chimtas were very losse so bought kabli chimtas and then old boots were replased with new ones.
the steering assembly was replaced with a kabli assesmbly as the old assembly had leakage.
all four CHIKHS as the mechanic called them or should we say helper were in good shape only the BUSH were losses so changed the bush
following are some pic rest will be uploaded tomorow.
