Salam!
1. My charade tikli (btw what is it really called?) reads E-G11-GMW and reads CB-35 against the engine and FDS2 against Trim. Can some one translate into understandable lingua?
2. I know the previous owner changed the engine, so it is CB-23 now. Any major difference?
3. Furthermore, the catalytic converter caution light is on since I purchased it. How to kill it?
4. Can anybody unlock the mystery of the tiny illumination panel reading ECONOMY which sits in between the speedometer and the tachometer under the fuel and temp gauges...?
5. The steering electric control panel is loose, squeaky and often the indicators wont auto shut after recovery from a turn, even after repeated maintenance through an electrician (probably because his suggestion / motivation was to change the entire system of meters and steering elec block with alto /cuore - which I disagreed to).
6. There is a constant low grind of some gears probably from the recently fixed odometer which was not working last couple of years. Where can i get it addressed?
Sorry guys for ONLY pouring out my problems so consistently.. With my level of knowledge, I cannot be of any positive value/help at this stage to these forums...just willing to learn at the moment, thats all!
