From last 2-3 days i am facing this issue that when the ignition switch is turned on no check engine light and no power steering warning light power steering works fine only the warning light on speedometer dosent come on and when the car is started check engine light comes on very dim every thing is working fine i tried removing the grip from a sensor to check if the light comes on but it stays dim what could be the cause the car in question is mazda scrum/suzuki every
Regards
Sent from my SM-N930F using PW Forums mobile app
