Aoa my move custom 15/18 is showing check engine light but I scanned the car with two different scanners and it doesn’t show any code or fault kindly tell what should be the reason
Is the check engine intermittent? Or it comes & goes away?
Intermittent
same issue is facing. Engine light is removed by disconnecting battry but it shows again after a or two days later. Scanner not showing any fault. Conte Move 2011/2015
