That will cause a no start on modern engines, and it will pop a tdc code too, it will also have a p0011 code which timing too advanced (usually a stuck variator pulley)
0340 is a wiring fault, which can involve the connector being broken or the sensor internal windings being broken or faulty.
This being Pakistan Im 100% sure - the replacement sensor being mentioned is a scrapped sensor.
