Hello! My Civic 04 started missing and on getting it inspected, it was revealed that its Fuel Tank, Fuel Filter and Injectors were full of Rust. Can anyone tell me as to how much the Genuine Injectors and Filter cost. Suggestions are also invited. Thanx.
Bump
dude kindly take honda number from 1217 n ask them for prices though u can clean the injectors too,there was this member on pw who does this in lahore
injectors are pretty expensive. you shud get the fuel tank cleaned, filter changed and injectors cleaned from the dealer.
I forgot the name of that product but it was from Liqui Moly that is used for injector cleaning. It is added in your fuel tank with some liters of petrol. Try that. It might save you money.
A couple of years ago, Liqui Moly had its workshop/office in I-10, Industrial Area of Islamabad. I bought a bottle of that liquid from there.
It should be something like this...
^it costs around 600. very cheap when compared to toyota injector cleaner (1600 rs)
unless you get the fuel tank and fuel lines cleaned and filter replaced there is no point in using injector cleaner as the injector will get clogged soon once again as the rust is still in the system
It is just to clean the expensive injectors instead of getting them changed. Obviously the root cause of dust and rust have to be eliminated.
Thanks Bros... My fuel tank is having RUST in it... Quite strange.. A fuel tank from used parts shop is for 15k. So now I think I should go for the Thorough cleaning and Liqui Moly option.
