The car is over a decade old and has a relatively small engine which means it's at the end of its lifetime. And as you might be aware; an internal combustion engine looses its compression overtime due to wear and tear which translates into oil burning and worse fuel consumption.
Check the compression first, specially if it has high mileage. A healthy engine should have over 100 PSI per cylinder.
Good Day!
