guys i have been using JDMs, first time its city here for me, i dont know if there are rear door spearkr and how to enable them, i have 2016 aspire 1.5 auto.
rear speakers are optional, if you didnt opt for them, you wont have them. if you opted for them check fader control on the head unitedit : rear speakers are factory fitted in aspire. Do try fader control or use torch to check if they are installed or previous owner removed them (saw your other thread that you bought it used)
ok thanks
i dont know where in the settings should i go , i tried all, can you guide more...
will check to see if they are removed but i dont think so...carr is all new condtion
its usually under settings where you set bass/balance/treble etctell me model number of head unit, or picture, it will be easier to tell. it will be in some menu probably
i have 2016 aspire 1.5 auto...
like this?is it touchscreen? move around settings like audio settings it will be there. cant tell you exact as I dont own city
Watch from 7:50 and click on main from there go to AV you will find it there InshaAllah
yes faheem thanks, i did it, got it, now i can configure all speakers,
by the way sound system mechanic was trying to do fraud, he said there are no rear speakers and i need to install in rear doors, be aware all guys...
yes they do such frauds. Congratulations on your new ride hope it serve you well InshaAllah
thank you,
