Brother genuine NSK and NTN Clutch bearing for your city costs Rs. 2200 & 2500 respectively and runs with the life of clutch i.e. 3 years or 50,000 km or depending your driving style.
When the mechanic will dismount the gearbox he will tell the condition of clutch plate. pressure plate and bearing.
Its a 3-4 hours labour mechanic probably charge 3-4,000 rupees for a clean job.
If you car accelerates well and has power to go beyond 150km/hr the clutch / pressure combo is fine.
If you are facing jerk or roughness in shifting gears the Bearing must be the culprit or it can also start making noise.
Honda in Pakistan uses genuine FCC clutch and pressure plate the set will cost you 15,500 for made in Japan and 13,500 for Malaysia.
Second comes Aisin /Asco which will cost around 9,500 for Japanese ones.
