You have manual or auto (vario) ?
In case of vario there is a gearbox "gararee" change required to make gearbox work with Paki L12A2 ECU. I had it changed as I was planning to run with paki ecu.
Now if I want to switch to L15A ECU (auto) then I need to get three things changed back.
1- Gararee back to the Japani setup
2- O2 sensor in exhaust manifold
3- EGR connected
I made a mistake since I got the couple (Engine + plus cvt gearbox) changed I should have added the ECU plus wiring too, instead of opening the gearbox.
Did you have all these things done??
