last night i changed battery of my vario then all brake light on automatically then i start enginewhen i put transmission it got jammed and stuck at Pwhat can i do for this is this big problem or????please help what can i dowaiting for your comment and suggestion
its something wrong with wire ....anyway u can use it manually press shift button change the gear P to D
do'nt worry, Problem in brake pedal's light button wire which link to switch unlock lever from P to D, check little tik tik noise during pressing pedal & check any good electrician.
thanx thanx
any other suggestion thn msg i will chk at morning thanx
If you dont know how to install a new switch but need to get it to an electric guy, use your key to unlock the select lever - and put it in N - start engine and use the R and D ranges.
