Whick should be Best For Modifications And Also Be a Comfart car..?Just to make A clean car and Some Lil Modifications. Like Wrap the Full Body, Exhaust, Project Lamps etc. Thanx
Definitely for modifications and for "shashkay" civic 95 is a best option baleno is so simple and also modification ideas for baleno is very less then civic 95 civic has wide range of modifications
I think Civic will be better than Baleno, considering your requirements.
What About Spare parts And Maintenaning Cost?
Reliability wise Baleno would be better. Modification wise Civic is more forgiving
Spare parts of civic is easily nd readily available as compared to baleno for baleno u need to put little bit of effort in case of finding parts but they are also available maintenance cost of both the cars are more or less same.Bro go for civic you'll enjoy IA
civic is much more reliable then baleno. this is all misconception that civic can't take the beating.
rather then exhaust and project lamps. get nice set of wheels and drop it (not to the ground though) on either of the car you get.
I agree, but I said that in the context that Baleno would be newer hence a bit more reliable.
Civic is your car for modifications.
Civic
Civic is best option for modification .
