you need to take of the plastic timing covers take of the timing belt. replace with genuine item UNITTA available at nasir
all belts must be off prior to welding.
proceed with welding, wrap a cold water damp cloth around the shaft and other parts to avoid weld splatter. only welded area should be exposed.
after welding, take of the cam and crank seals, genuine NOK seals can be found from Hamza Oil Seals (plaza market) 03232102202 Raza
put in new seals.
