A - Radiator Fan Relay
B - A/C Compressor Clutch Relay
C - Rear Window Defogger Relay
D - Blower Motor Relay
E - Headlight Relay 1*
F - Headlight Relay 2*
F - Headlight Relay**
G - Condenser Fan Relay
H - Horn Relay
*2001 model
**2002-2005 models
1 - Condenser Fan Motor (blue/yellow wire) / AC Compressor Clutch (blue/red wire)
2 - Audio Unit, Dash Lights, Front Parking Lights, Front Side Marker Lights, Heater Control Panel, License Plate Lights, Rear Side Marker Lights, Taillights.
3 - Ceiling Light, Ignition Key Light, Spotlights, Trunk Light
4 - Radiator Fan Motor
5 - Turn Signal / Hazard Relay, Turn Signal Lights
6 - CKP Sensor, ECM/PCM, Injectors, IAC Valve, Immobilizer Control Unit Receiver, PGM-FI Main Relay 1 and 2, TDC Sensor.
7 - Horn, Brake Lights (to ABS Modulator Control Unit, Cruise Control Unit, ECM/PCM, Multiplex Control Unit)
8 - ABS Modulator Unit
9 - Audio Unit, Data Link Connector, Gauge Assembly, Immobilizer Control Unit Receiver, Immobilizer Indicator Light, Keyless Receiver Unit, Multiplex Control Unit, Security Control Unit, Audio Unit.
10 - ABS Modulator Control Unit
11 - Rear Window Defogger (via antenna module)
12 - Blower Motor
13 - #7 fuse (in the under-dash fuse/relay box), Power Window Relay
14 - #3 and #16 fuses (in the under-dash fuse/relay box)
15 - Daytime Running Lights Control Unit (Canada), High Beam Indicator Light, Left Headlight. (01-03 use 15 amp / 04-05 use 20 amp)
16 - Multiplex Control Unit
17 - Daytime Running Lights Control Unit (Canada), Right Headlight (01-03 use 15 amp / 04-05 use 20 amp)
18 - Battery, Power Distribution
19 - Ignition Switch (BAT)
ALT = Alternator
BAT = Battery
ELD = Electronic Load Detector
X = Spare Fuses
