the idle speed is not adjusting correctly and most probably some mechanic tried to adjust it with a cold engine, The thermostat valve will allow the engine to achieve normal temperature and the ECU will release the cold start high idle.
So - yes the problem is the missing valve - once you install it and start a cold engine - the rpm should be 1200 - and after a minute or two it should drop back to 800.
