I want to know that changing gear oil does affect the fuel mileage or not. And what is the location of gear oil drain and pouring bolt? Of Honda Civic 2003 manual.
I am getting the 9.5 kmpl on local and 13 kmpl on highway without AC. Stock engine no oil reduction. Using oil is shell hx7 5w30 all filters changes fuel,oil,air,ac. Radiator is filled with coolant with auto fan. Changed injectors with kabuli set also because ealier they were dumping more fuel which causes the black smoke. All alignment and suspension done. Tyre are 195/65/15 Micheline with alloy rims. With no error in ecu or check light. I have got to know that it has Ideal fuel mixture potentiometer under the glove box which has reading of 2.03v i asked and saw it while when i was inspecting the while mechanics were doing their jobs. And there is no tappets knocking sound
