inspect power steering feed pipe for vibrations... if the pump is noisy, u will actually feel the vibration.
Next - open the reservoir bottle cap and turn the steering lock to lock a few times...see if it helps...
Inspect oil level and see if there are any leaks... if ur using the original power steering oil (honda's which is transparent) , u can replace it with the same oil.
