Hey guys, My Civic 2017 is showing multiple warning lights one day after the engine wash. Didn't show any warning light on service day. Started showing the warning lights one day after the service when I hit a bump. Every system is working fine. Can you please help?
Remove battery terminal
Reconnect after 20 sec
Thanks alot for replying and is it a common problem in civic? also is there any permanent solution to this?
Don't wash engine
Better to avoid washing with water
If you want, then don't wash engine with high pressure water.
You can wash with very light pressure .
Let it dry
Then start .
If the battery terminals (ground between battery to engine and body shell) are corroded you need to figure it out as DIY and fix it. if problem persist, trip to workshop having scanner for Honda will help.
Thank You all for the replies, Started the car today and no errors at all,,,,drove for 50kms and no error
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
