I'm in the process of restoring or revamp of sorts so I have changed all of the above not more than a couple of months ago. I'll give you the details.
Tyre and Rim size are the stock, 13 inch. I recently bought both a couple of months ago, stock 13 inch rims with Dunlop SP Touring series tires.
Air pressure is kept between 30-32
Front discs replaced, pads and rear drums replaced not even a month ago
Suspension fully changed front back, nothing was bought used, all new parts and obviously new rims and tires were bought and fitted after the suspension work was completed, balancing and alignment was done too.
From what I have read, this issue may be caused due to a jammed caliper but I'm still reading and learning about it and would appreciate all the help I can get.
