i started project of civic 95 in a very tight time and also in my tyt schedule.
bought a decent looking 95 with rough paint putty and alot of rough edges with carby engine and suspension which was at its end life .cng .
list of parts replaced
front bumper brand new
rear bumper brand new
hood new
both fenders new
dashboard along with ac heaters boxes all new
meter cluster new with check light.
front lights aftermarket
back light aftermarket
all four doors rubbers
all four doors moldings included boot
all four inner handles/outer handles
Power window motors
Jdm vipers.
SIR fender lamps
duck tail spoiler
body kit
ENGINE
D15Z7
3-stage VTEC
Found in:
1996-1999 Honda Civic VTi EK3 and Ferio Vi
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 mm ? 84.5 mm (3.0 in ? 3.3 in)
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.6:1
Power : 128 hp (95.4 kW, 130 ps) @ 7000 rpm
Torque : 102 ft?lbf (14.2 kg/m, 139 Nm) @ 5300 rpm
Valvetrain : SOHC VTEC (3-4 valves per cylinder, depending on rpm)
VTEC Switchover : 3k?200rpm (12-16v crossover) rpm 6000?200rpm (Aggressive cam)
Fuel Control : OBD-2 MPFI
ECU Code : P2J
Engine and suspension
fresh d15bz7 got a very good piece
fresh injectors
new belts
new engine mounts
s40 gear with fresh clutch plate
uncut wiring with p2j003 with active check light
complete suspension replaces
new power staring rack
4 shocks along bushes all new
4 wheel disc front bigger rotors with 95 back rotors
handbrake cables
new brake pads
aftermarket stuff
recardos
black racing 15 inch usa
led back lights
front aftermarkets lights
honda red logos
led projector fogs
air intake
paint
complete old paint stripped for new
pictures coming up
