The bearing on that pulley is easy to press on, but when it comes to placing it on the compressor snout, it needs to be assisted with tapping the inner race only.
Finally, is the clutch in good condition? Meaning its not worn out badly and has a very large gap,
If need be install the pulley and pressure plate on a lathe and polish the surfaces then set the gap right.
A loose gap and cause chattering which will cause the clutch to overheat and roast the bearing.
Also make sure the splash shield under the car is intact, it prevents water damage
