You are right but its not stock, was already swapped with 1.5L 1NZ-FE. I am not too much concerned about fuel average, just want some more power than the current motor with a little bit fuel average (it should not be a gas guzzler). Again you are right, I searched about 1ZZ-FE, 2ZR-FE & 2ZZ-GE fuel average and it turned out that both 1ZZ-FE & 2ZR-FE have almost same 15-16 km/l (highway) fuel average while 2ZZ-GE would give you about 14-15 km/l (highway) if not rev very hard, now I am seriously thinking to try this motor. Only problem now is high octane fuel as it is not available everywhere? Where can I find 2ZZ-GE in good condition? Should I get this engine from front cut or without front cut?
You are using 6 speed manual or 5 speed? Do you use high octane fuel for your motor? From where you get your motor, front cut or without?
I am talking about the gear lever/stick which is 6 speed having 4 cuts unlike in 5 speed having 3 cuts? Under gear console or in gear lever/stick I don't care what ever modifications can go but I don't want to do any modifications in gear console.
Still waiting your PM regarding these:
Contact info & address of "All Motor Automotive"?
Swap chargers of your swap which they charged you?
Thanks.
