Thank you for that info sir, we found the PCV valve, it was in working condition according to the mechanic but I will get it checked once again to be sure, I did start reading about it and how the whole system works, seems like a really crucial thing in leakage prevention and often at times overlooked.
99 percent of the issues are now sorted, car hasn't leaked or anything but next month I think I should get the valves adjusted to where they should me.
Now in this I believe I will face a problem...
Last time, when I got the tappet cover gasket work done, the kharaadiya used a tapping thread tool to just install a thread for two bolts that were slipping and tightened the bolts, ideally what should be done for an aluminum block (as I've been told) is that you would have to install a sleeve/thread made of a harder metal inside the hole and then tighten...this step was skipped and I found out after more research that it shouldn't have been..
Now if we try and open the tappet cover(to adjust the valves) .i fear that it won't retighten and we'd have to take off the head and get this fixed...
Any advice in this regard?
