Need Expert Advice for civic exi
Following things Done.
- Clutch set Changed recently.
- TB washed many times and changed too.
3.MAP and Iat Sensor changed.
4.No Error Codes.
- Coils changed and Injectors(mechanic brought a set from his junk at his shop) are washed and Changed once.
6.Tappets Done multiple times.
- Fuel filter and Fuel pump changed 5 times with new and used so called kabuli.
8.Silencer acidified.
- Car is late to respond to pedal and also give too many jerks on first gear and lite foot when speed is is about 10 to 20km/hr on top gears almost no jerks.
Issue is burning smell from exhaust and the pickup of car. burning smell is here from last 3 years and so is pickup issue. mind u when car is cold and moved steering is light but when car get hot steering is heavy a bit looks like car enigne is in load Car seems to be going slow as compared to speed. looks like its under load even after doing everything. i believe removing the unburnt fuel issue will resolve the pick issue. average is also low. its exi manual. any one in pindi who literally can fix the issue and has technical knowledge?
