Aoa PW
I have a civic exi 2005 which is known as eagle eye, Day before yesterday my mother had to go to somewhere she started the car but it didn't started(Car was taking sulf but engine was not starting) it was about 8 in the morning before it was fine i thought its some electrical issue i called my efi mechanic he came to my home as car was not starting he started checking wires and stuff removed CNG connection but nothing worked each and every ELECTRICAL thing was working and every current was fine then he called his friend who was also an eletrician he came and checked somestuff checked petrol line petrol was coming he hooked up ECU's that he bring with him to check but still car didn't work then he took out plugs cleaned them and again plugged in checked still same issue after that he said that plugs have petrol in them we have to heat them he heated them so that petrol in them burns and we can use them after doind that he placed them back but still the same issue he said your battery is down as you tried to start it several times he got a battery from rent but that was also in vain at laast he said we have to push start it i mean dhakka start i asked my neighbours to tow my car so that we can start the car atlast car started and that a$$hole asked for 4k and i was shocked dafuq what have you done he said that he starts a car for 10k and stuff but after negotiations he agreed at 2k (He didn't replaced anything just open and close everything) now yesterday i started the car it was fine but i didn't drove there were rpm issues rpm was not stable now today i tried to start the car now still same problem i called them back he said he will come tomorrow and check let me tell you guys that this car was bought used roughly about 6-7 months ago can spark plugs be the issue or what?? as i didnt change spark plugs till then but the mechanic said plugs are fine as current is coming PLEASE HELP ME BROS AND GUIDE ME WHAT IS THE ISSUE and now when i turn on switch i smell petrol but cant find anydrop anywhere but can smell only I am helpless I already lost my 3k
how much is your car driven ?
Aproximately 130k
Did you try to start it on cng ?
better get it towed to a proper mechanic or 3s.rather then wasting your money on that idiot
Yes tried but in vain
Sent from my iPad using PW Forums
Car was washed before that problem appeared but it was washed from outside only
@mewithwishes bro I have no option other then local mechanics car is at home
@fahad.Ayub what could be the issue by light of your experience
get the starter motor checked it might have gone bad
Thanks I will check it where it is located? In the ignition are?
brother im 19 what experience would i have before joining Pw i was a complete noob but know have a little bit of understanding how things work one of my car got its engine replaced and the mechanic couldnt get the car started in 5 day whole days he called dozens of electricians who said everything is fine but still the car wouldnt start towed the car home got it running in less then half an hour
Being a senior pak wheeler you would be having experience , so the issue in your car was starter motor..?
I called my electrician he said that it's not an issue of starter motor as car is taking self but not starting
no its connected to the fly wheel locally called "self/sulf"
the starter motor went bad also the alternator(generator) was repaired
Generator was repaired before of my civic too
wait for xulfiqar bhai's inputEdit: does your car have a security system installed ?
yes it does has Security System installed @xulfiqar bro waiting for your help
If you car has central locking system then check it has a fuse in it red coloured which mostly gets loose or if engine is washed excessively you may have to replace it or fuel pump fuse might be bad. This is electrical problem for sure.
