AOA Brother
Welcome to the civic club you are family now
For maintenance of civic model 2005 or 06
Ngk plugs or any other ?
NGK Iridium BKR6EIX-11 Rs. 950
ZFR6K-11 will also work goods same price.
Denso KJ16CR-L11 normal Rs. 100/plug or IK16L iridium Rs. 900/Plug
air filter leppon brand or which brand is best ?
K&N genuine air filter brown color for Rs. 2500 or OEM honda for Rs. 1250.
oil filter guard or any other ?
Bosch long life Oil filter or Fram oil filter or genuine honda OEM from 3S Rs. 1200 NO GUARD
oil castrol GTX or what ?
Mobil 1 5W50 or liquy moly Synthoil 5W40 Rs. 3900 if new engine.
Old engine more then 1 lac KM Mobil 1 Super Rs. 1900
Break oil ?
Mobil 1
radiator coolant caltex green one or any other ?
Genuine Type 1 Honda coolant Red & white Rs.850/litre four litre needed for 5 years or simple fresh water.
Any other coolant will damage radiator and engine block both aluminum.
gear oil for manual ?
Genuine Honda MT oil Rs. 850/litre if not available any mineral engine oil of 10W40 like castrol gtx works temporarily caltex delo gold also works goods.
transmission oil for autos ?
Genuine Honda ATF Z-1 Red & white 3.5 litre so 4 bottles needed for Rs. 950 each.
Never use CVT one its for old city vario / steermatic, honda life, airwave, honda fit etc.
Ideal tyre size for long highways routes ? And tyre brand ? Tyre pressure ?
and reputable alloy rim brand ?
Genuine OEM VTi rims 7 spoke best of best or lenso rims of your choice with FWD offset are best 195/65R15 30 PSI all tyres, eurostar new for Rs. 5000/tyre will do Dunlop Lemans LM704/703 japanese for 6500 and Yokohama Advan DB for 9500/tyre accroding to budget.
Honda charge 35000 for OEM alloy rinm if still in stock and kabar will ask 25000 in genuione condition.
no headache of PCD.
hids brand and watt ?
any chinese hids look good for Rs. 3000 if headlight are clean.
depo fog lights are 7500 glass chinese are 2500, Rs. 3000 chinese HID can be fit in depo or chinese fog light assembly.
Branded HIDS cost as high as 15000 and philips bulbs re also available for Rs 1000 onwards.
two more questions.
Is this possible to install reborn steering in subject model ? If yes then pls share price and availibility in karachi.
Rebaran steering is 33 spline column and fitted in 2001-05 cvici and 98-2002 CF3 accord & CL7-9 also.
Reborn steering could be find from kabar shershah but must be preety espensive around Rs. 12000 from kabar plus with your original sttering and electrician charges labor rs 5000 for jugar / sensors.
Honda 3S would charge Rs. 28000 but never install it.
Which has best fuel average ? Auto or Manual
Manual has dfinitely better fuel average 15-30% better depending on traffic but in Karachi traffice u will never drive a manual once u have driven a prosmatec not for free even.
hope that helps.
