@ HASSANMURAD
I just want to post few ideas and want to know if that can be done. There is option of TV in navigation panel so is there any option on backside of the panel to attach antenna with it and will channels like PTV and STN work with it then. Or is there any other way I connect TV to that navigation panel.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
</B>
Dear the TV Card is not installed in this unit. I open mine unit and checked.<o:p></o:p>
Secondly, how do we use REAR Camera while not in reverse gear. There is a option of rear in Meny but when I click on it it displays black screen. There is arrow on the top right when I press it and enters code 0000 it accepts and give me option to confirm but when i press it nothing happens. (0000 is accepted while any other code it gives error)<o:p></o:p>
You can use the reverse camera at the driving time also but you will hear the beep sound at the same time and audio system volume is also decreased same as your car is in reverse gear. I already do the experiment. However if u want to have the camera while drive and hear the music, you may use the other video input with separate camera<o:p></o:p>
Thirdly, my memory card SD is on FAT32 file system with 5 folders and 10 songs in each folder but the system does not play it. Does anybody know why and how can I use it?<o:p></o:p>
I didn’t notice any problem regarding song or video play. I also convert my favorite movies in .vob format and movies are playing fine on DVD player.<o:p></o:p>
Fourth, How can I update my maps and stuff because i think its outdated.<o:p></o:p>
Get the new image file when it’s available @ NAQSHA.pk. and install in your existing map card. This image will replace all the old maps with new one. Right now no upgrade available.<o:p></o:p>
I have a trick to change the picture that you see when you switch off your navigation mode. Open the memory card in your computer and you will see that ROAD picture. Open the picture in Paint Brush and edit as you want. You can paste your picture or add text to existing picture. customization looks good. I have done that and it works. (To avoid problems first copy your memory card as it is to your computer as a back up)<o:p></o:p>
You can also change the startup picture of DVD player.
