Hello guys, i own a 2010 Honda civic vti oriel prosmatec. Its in good shape, driven on petrol and has about 1 lac km on it. The car was driving fine but i started facing weird heat up issues all of a sudden. I had the thermostat valve checked which was jammed, i had it changed. This caused the car to not heat up frequently. Then i had the radiator serviced, no leakages were found and it was just choked, had it cleaned. The car stopped overheating, the ac worked great. I live in karachi, the summers are very hot here, the car starts overheating after you take it on a long route and it cools down by itself after some time, I don't understand why the temp dots go up tho. And there is no leakage. The only issue i was told is that the condenser for the ac is damaged as its fins are all bent. I'll bought a new one and it costed 6k rupees and with the installation and ac gas and labour it will cost 10k rupees. However I'm afraid it'll heat up again. I need proper help on why it is happening. By the way, the head gasket is perfect, the engine runs and sounds great and there are no foamy bubbles or water leakages found in the engine oil so please don't ask me to have it checked.
