Hey Guys!
Thanks a lot for your input. I think i have been convinced to get a DEH-80PRS, read some reviews on Amazon and everyone is raving about its SQ and auto EQ, now i just hope it doesn't break the bank. Will check for prices. Anyone knows the estimated price bracket?
Fronts are confirmed, PS 165. Where is the Focal outlet located in Lahore?
Disclaimer: I am going for a SQ Setup, but like i mentioned before, the low frequency range should be properly covered, with good solid/deep bass when required. Hate it when subs crap out, on my PC Creative Megaworks Sub (I know i shouldn't compare, dont shoot me for it)
Subs, i am a bit confused. I heard a lot of good stuff about the Infinity Kappa Perfect 12VQ but it looks like its a rare to find sub. Incase i cant find it, which is the correct proper alternative? the JBL GTO 1214 or the JBL p1224? And there is the last option of the Kappa Basstube with Amp Madhouse mentioned, i've inboxed him for more details/price. If you read here first, you may post here as well
Amp, again a little more guidance would be helpful. I selected the 8604 because i've been reading its a good amp. Also, (please confirm) it should be able to give out 80 RMS each to both focals (they are rated at 80RMS) and 300 RMS at 4Ohms to the Sub. All the subs i've mentioned above are 350-400RMS at 4Ohms. Now i haven't been into car AV electronics much, but everyone talks about being able to run them at even lower impedence? So is that a thing? Makes them run louder/better? Do people usually run subs at more than their rated power on SQ setups? I would obviously prefer for now to get a single amp, (to save money) but if i'd have to sacrifice a lot of sound quality for that, i will look into getting two amps.
Also, how does the 8604 compare to the SS 800.4? But again, i hear the SS is difficult to find, and with my luck, i'm not sure if i'll find it.
Will keep in mind, the 4 Guage kit for the 8604. If the amp changes, will ask again and confirm.
As for the dampening, like mentioned above, doors will be opened waisay hee, so doesn't hurt throwing in some insulation, but which one? either i've seen people installing Jumbolon (which is cheap and that is good) or dynamat (which is expensive and way out of my budget)
Thanks for all your input guys, Much appreciated.
